in case anyone cares, the lcd4bit.h file can be edited to change the pin assignments to fit your needs. you just need to make sure to assign the right pins to the right wires connected to your lcd. I didn't change mine, only used it as a reference when wiring it up, so my code should still work with the standard pinout.
