Old 05-01-2014, 08:39 AM   #94 (permalink)
serialk11r
Originally Posted by Old Tele man View Post
Did you also notice the more than DOUBLING of Unburned Fuel loss--from 2.8% up to 6.4%--on the Heat Balance chart?
Mazda was working on laser ignition plugs for the rotary engine, and I think when push comes to shove laser plugs might get widely adopted to squeeze out an extra 1% or whatever in fuel efficiency, because they don't take much space in the combustion chamber and can have multiple ignition points to reduce that unburned fuel loss. But if you're talking a lean burn engine, the multiple ignition points means the temperature will also go up slightly and you'll have more NOx to deal with.
