Originally Posted by vrmouseyd15b
makes perfect sense. at that point, can you tell me how the "power and econo" buttons hit the ecu? I'd like to think If there was an "econo" switch engaged ( on the steering wheel on a vx? never seen it, only read about it) it would let me lean burn into part of the 16v operation, maybe.
There is no econo switch. You might be referring the sport mode switch they had for certain models of cvt. I wanted to try it out, I even picked up an d16y5 with the cvt, ecu and tcm. I ended up junking it because my dad was complaining I had junk sitting around, can't complain its his house. Right now my d15b is running the d16y7 ecu for inspection purposes but I'm ready to switch it out to a 5spd and run the manual p2j-j11 ecu and my gas mileage will be better.
