Old 05-01-2014, 03:01 PM   #3 (permalink)
some_other_dave
Originally Posted by mazdamx640 View Post
... I want to rewire to fuel pump to up the pressure and help the fuel atomize the fuel better.
The pressure can be raised by simply changing out (or adjusting if it is adjustable) the fuel pressure regulator on the fuel rail.
You don't want to do that--higher pressure means that more fuel goes into the engine per millisecond of injector opening. So unless you have a way to re-map the injection times for all driving conditions, you will simply be making the mixture richer, and burning more fuel.
I think you've probably done just about all that can be done to help your MPG with bigger wiring.
-soD
