I don't think you can use the an MPGuido with an OBD-0 car, can you? If ya can I would much rather go that route. The only reason I was gonna use a vacuum gauge is the ease of install, low cost and bein OBD-0. Also, my tires are up to 47 psi, which is 3 psi above sidewall pressure. I would go higher, but they're older tires but still have good tread aaand I have no job right now, so I can't afford new ones. But ya, these older civic are awesome, this is my 3rd fourth generation civic and I always end up kickin myself in the ass after I sell one.
