Old 05-01-2014, 09:42 PM   #30 (permalink)
Cobb
The Peter Perkins modes allows some manual control over the IMA system. What you do is use the ima system to supplement the power output of lean burn and you abuse this to get epic mpg. Some people go as far as combine a glide session and coast as far as they can on what ima and lean burn will give, then when you hit the bottom of your target speed pulse back up on gas to the upper limit and repeat.
