Old 05-02-2014, 02:00 AM   #5 (permalink)
ecomodded
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Originally Posted by jumper View Post
if I doubled the batteries, how would that effect range and mph?
I would like to get 35/40mph with a range of about 20+ miles.
thanks
Double the batteries but keep the same voltage will double the distance range.
Double the batteries but double the voltage and you will get "more" speed.
But (as mentioned) there are losses in efficiency due to the electric motor/ wind resistance & various frictions that increase with speed. You don't want to go to fast or have a heavy vehicle so it will be more easily powered, just keep the weight down.
You need to size the motor to the vehicle weight and size the batteries to the vehicle weight & motor + distance and your speed desired.
Do I know the math for that ? No but its out there
Save gas
The Following User Says Thank You to ecomodded For This Useful Post:
jumper (05-02-2014)
