Old 05-02-2014, 04:24 AM   #6 (permalink)
niky
For a new car, it's usually a fruitless task, but considering it's a 96, there might be something found there.
Personally, I'd sand down and clean all the contacts first, on both the wiring and the grounding wires/straps and see if that makes a difference. Might be cheaper than going through the car and changing out absolutely everything. But if you find cracked or brittle rubber, might as well change that out.
