Old 05-02-2014, 06:35 PM   #206 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 38.8 mpg (US)
The Superbrain charger that I used can handle much more amperage. Based on a post here I used 7 amp charge and 10 amp discharge. So it sounds like you will need to just use the max settings on yours. As for cycles I sometimes ran four or five if I didn't see the results I wanted after three (>5,500mah)
