Old 05-02-2014, 09:56 PM   #207 (permalink)
Cobb
Most people use the max settings so they can compare apples to apples. In real world use in the IMA system they will see way more. In other applications less is used. Many use older ima cells for ebikes and such.
May want to get an ir temp gun to check the temp while you are cycling them.
