The kill switch is a good idea, I will install mine at the end of May.
For the tires I put 50 Psi but I think I could go a little higher, like 55. I wouln't go higher because (you know it) of the pretty bad conditions of the roads here in Quebec.
There is an interesting correlation between ecomodder and Laval.
