Old 05-03-2014, 08:22 AM   #33 (permalink)
Xist
The Quick Valve is in the mail
Originally Posted by dustyfirewalker View Post
like sheep dog said try fumoto if you havent really screwed up or bulged the threads with a bigger bolt. same issue on my 460 and now no leak. use rtv black when you put it in, the brass valve threads are soft so dont over tighten
Warning: leaks don't seal themselves.
I have a Quick Valve on the replacement pan and I know better than to expect problems to go away, I just have not seen it again.
Well, I should get to bed. I need to be up in an hour for drill! Who plans drill immediately preceding finals?!
