Have you tried switching over as many lights as possible to LEDs?
Most of mine are LED. I don't have a problem with lights, but if I go above 2 on the blower motor, my ELD sensor "freaks out" and goes into a surging idle (900-1500 cycle). Not sure if its an issue in the circuit or normal amp draw. Either way seriously considering bypassing the ELD on this circuit since 95% of the time I'm at 1700rpm + (minor loss of voltage at idle is temporary).
