Old 05-04-2014, 09:25 AM   #7 (permalink)
iveyjh
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
Originally Posted by cbaber View Post
Is it the same readout of 0-125? The SG also has codes to enter that are listed as A/F Ratio Sensor 1 Bank 1, but when I enter those in no data shows up. Honda must not display that data, which is a shame because the actual A/F ratio readout would be more helpful than just the voltage.
Do you have similar experiences with lean burn conditions? I was a little worried at first because I have a cheap(er) O2 sensor. It game me codes and trouble until I figured out my non-OEM exhaust manifold was the problem. Switched back to an OEM setup and LB started working again, codes gone. The only thing now is that my EGR valve is broken. I actually have the connector disconnected from the EGR valve, so another interesting FYI, the LB works without EGR.
On the UltraGauge it will read from 0.00 to 1.25 so just multiply 100X and you get the ScanGauge readings
