As for the brakes modern brakes already have "back up". Modern master systems are dual units. If one of them fails the other still works.
If you want to test this cut your rear brake line and drive your car. Yes the brakes will go the floor but you know what the front brakes will still work.
This has helped me in the past when I blew a brake line. Like I said the brakes still work just not real good.
