Old 05-05-2014, 09:46 AM   #213 (permalink)
msantimanzano
I could. Will it not be a problem that I would therefore be connecting a positive, and a negative lead from 2 chargers to the same connection at the same time? This is what I mean. On one end of each pair of sticks, the pair has separate connections like this.
[IMG][/IMG]
On the other end however, the ends are spot welded together like this.
[IMG][/IMG]
I figured I cannot do both of the sticks on this set for example, at the same time because that would mean having both a positive and a negative from two separate chargers connected on the same terminal. I know I can do them separately at different times, but I figured that since both sticks are part of the same pack, which I cant separate anyways, it would be pointless no?
Bottom line though is that if you guys think it's best I do the sticks separately, thats what I will do. You are the ones with experience and knowledge on this, not me, so I am opting to go your route. I rather draw from your knowledge on this than my untested knowledge.
2006 Accord Hybrid
Self installed OEM Navigation System
I am a federal firearms dealer and gunsmith by trade
