silicone emits acetic acid on cure and reacts with steel. neutral cure silicone is best. not much steel except that screw so you should be good.
ASI 335 Neutral-Cure Silicone Sealant/Adhesive
FOR SALE: 02 TDI Jetta- 5 sp: Cooper CS5 at 50 psi, UltraGauge, ventectomy, rear air shocks, mufflerectomy, LED plate light, upper fiberglass grille block, front lower pan, front fairing.
93 Chevy CrewCab 6.5 TurboDiesel, GearVendor OverDrive, 4L80 w/ TCI controls. Now DailyDriver
