Old 05-05-2014, 05:56 PM   #3 (permalink)
MickZ
Hey, thanks for the response.
The webpage that you reference for the trouble code also says VTEC pressure solenoid for Code 22, the same info I pulled up elsewhere. If it's one and the same as the oil pressure switch, then great.
I checked the oil level, and it was just below the lower notch, so it was low. I brought it back up to full and drove the car around the block twice--it still had the problem (not sure if it needs to be driven more or if topping off the oil would remedy it immediately if that was truly the problem). I will definitely go unplug the O2 sensor and give it a go. It's funny, because the previous owner had just put a new one in before I bought it. I believe it is an NTK.
