Dont get too anal with the settings.
This isnt an exact science and a hobby charger is not what the pros use to test these cells. You want to be able to compare your results with your neighbor or someone in another city in the same boat with you.
If Jim just uses a hobby charger out of the box on the nickel metal setting, Kim, so should Joe so they can compare the results on an even playing field.
