Old 05-06-2014, 05:55 AM   #92 (permalink)
paulgato
Black Beast - '02 VW Goff Estate S
Originally Posted by ctgottapee View Post
Yeah, it's a 1993 factory AC Delco model.
It's not even the worst offender in the car.
The premium systems in the car use a lot of juice too. I guess the reliability of cold start electronics was low then. My power seat controls/system is always powered so it can auto adjust based on the keyfob used (set per driver) before they sit down when they unlock the car.
The exterior key lock is always lighted, run by a 15w bulb and a long length of fiberglass filament; kinda creative before LEDs existed.
And there is an air compressor that inflates the rear shocks as a ride control mechanism. It's not air tight so it is also always on, and occasionally runs to push the bladder back up while sitting.
I have climate control, but it still uses the resistance elements for fan power.
I have to agree with Oldtamiyafile. That's a huge amount of parasitic battery drain when parked. A 15w bulb for the door lock....!!!???? 15w!? That's more than an amp. Over a weekend that will flatten your battery dead, won't it? Is it really designed that way? That can't be right. If it is then maybe you could remove the bulb, and fit a hard ON/OFF switch for the radio.
My total battery load with key out of the ingintion is 24mA.
