Old 07-09-2008, 11:30 AM   #71 (permalink)
ebacherville
Veggiedynamics
Volt12 - '12 Chevy Volt base
Originally Posted by bennelson View Post
You know you're an Ecomodder when This:
Turns you on more than This:
damn the shot should have been a bit lower.. I can't see the radiator block... and that peach colored body should get a block in the hole in the center .. its causing a high pressure area..
