The cycles I ran were discharge then charge. Stick 9, first cycle, discharged 1427, then charged 4456. I am concerned that because I left all settings at the default levels the charger may be set to charge a lower amount than it should for these particular batteries. I don't know if that is likely or not. Cobb, none of the cells got too hot to touch, all of the sticks got warm/hot at different times of the process. I checked all cells with laser temp gun. The hottest temps were 118, with all cells in that pack hovering the same range. All 3 sticks saw temps up between 115 to 118 at different points.
Should I adjust specific settings and start all over? Since the factory specs say my battery pack is a 6000 amp hour pack, shouldn't the batteries have taken around 6000ah instead of just over 4000?
2006 Accord Hybrid
Self installed OEM Navigation System
I am a federal firearms dealer and gunsmith by trade
