Old 05-07-2014, 02:32 PM   #8 (permalink)
backpacker3
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
Are you saying Subies AWD is just like driving around in a 4WD with the transfer case and differential(s) locked up???
The front wheels travel farther than the rears; even if all four tires were perfectly 100% diameter matched, this would be true and the front/rear power split needs to accommodate it.
I reread the op and it's 80% tread not 20% in that case it should be ok but subaru says that there should be no more than a 1/4 inch difference in circumference and ideally less than that.
It's not like locked diffs the problems is that the awd system keeps track of how the wheels turn and when one is larger or smaller it seems like that wheels is slipping to the awd system and it's constantly trying to correct it but it eventually will either burn out solenoids or cause mechanical failure. Google torque bind in subarus for the more technical explanation of it though
