Old 05-08-2014, 07:23 AM   #1 (permalink)
redneck
100 + hypermiling tips ...
I was reading over the tips and found something that the administrators may want to amend.
44) The most efficient way to slow down
When you *have* to slow down, here's an approximate heirarchy of methods, from best to worst.
1) coasting in neutral, engine off (ie. roll to a stop);
2) coasting in neutral, engine idling;
3) regenerative coasting (hybrid vehicles)
4) regenerative braking (hybrid vehicles)
5) coasting in "deceleration fuel cut-off" mode (in gear, above a certain engine RPM)
6) conventional friction braking (non-hybrid or hybrid)
Choosing the right method depends on traffic conditions (following vehicles) and how quickly you need to stop.
Manual or automatic...???
As we know, EOC in neutral with a automatic is a no-no.
It is well addressed in tip number 55. However, a reference here may also be helpful. We wouldn't want newbies to make a expensive mistake should they not fully read all the tips or understand the implications and or limitations of "Engine off coasting" a automatic .
A reference to tip number 55 could be added.
Just a thought...
user removed (05-08-2014)
