Old 05-08-2014, 05:40 PM   #7 (permalink)
cRiPpLe_rOoStEr
Another way to improve the efficiency while running gaseous fuels is a higher compression ratio. If you would eventually consider to use forced induction, a selective overbooster can be used to emulate a variable compression ratio, allowing you to still run on lower-octane gasoline without knocks.
