Old 05-09-2014, 08:52 AM   #10 (permalink)
kach22i
I've built some models using coroplast, and agree with others in this thread about it's limitations - and no 3D or complex curves.
Thermoplastic Construction - Boat Design Forums
http://ecomodder.com/forum/showthrea...ept-20793.html
If you set up a jig like you would for bending metal, that is to say support the edge to be bent and then bend over an arc as large as a barrel, and ending with a curve as small as a mailing tube or PVC drain pipe with many steps in between you may have success.
Or you could just cowboy it like I did, and trim off the wavy edges (where I grabbed and pulled on it) as waste.
The Following 3 Users Say Thank You to kach22i For This Useful Post:
aerohead (05-09-2014), Cd (05-16-2014), mikeyjd (05-16-2014)
