thank you for the ideas & suggestions
Cbaber, as far as I know the suspension has not been modified and the car is original height. I want to do the easier things myself, and might have a shop check the alignment after that. The car is not bouncy, and has relatively low miles, so maybe the struts are okay for awhile.
Kennybobby, I'm impressed with you doing your own alignment, will check your previous messages and do the things you've suggested.
Vman455, I'm looking forward to doing the things you've suggested. Thanks much for all the helpful comments.
