Dual disc brakes stop the MadAss 125, a 260mm rotor front and 215mm rotor rear. Low-profile tires (90/90 front, 120/80 rear) adorn the 16-inch cast aluminum wheels. The seat rests at a rather tall 33.7 inches off the ground at the rear arm of the frame. The frame also stores the 1.22-gallon fuel capacity, with claims of 85-110 mpg efficiency from the 209-lb gas-sipping design. ''
2010 Sachs MadAss 125 First Look - Motorcycle USA
is something of a disadvantage but moving it forward would drop it a few inches.
