No contest, this beats the C90 hands down
The motor should be ideal and the frame construction looks as though modification will be much simpler. Plus you have decent brakes to start with!
My first thought to get a lower seating position would be a longer swing arm as per Alan Smith on Craig Vetter's website.
I hope you go ahead and look forward to following the thread if you do
Regards
Pete
