This is something I want to do but I have a question about the current Prius design. Would this require a rework of the entire rear end? Or will a continuation of the current slope work? For reference.
Using the tool to overlap the template this is what I ended up with. Not sure if it's correct though. If it is, despite the looks, the Prius is not quite shaped right.
Thoughts?
