Old 05-11-2014, 10:50 PM   #14 (permalink)
DOFZO
DOFZO's Avatar
SLOMOTO - '92 Honda Civic VX
90 day: 56.49 mpg (US)
Originally Posted by Old Mechanic View Post
Not sure about true vacuum in the PCV system since it is basically a controlled vacuum leak, purging crankcase vapors to the intake manifold. I don't think the VX even has a pcv valve, just an orfice (from memory, could be wrong).
Booster line is absolutely manifold vacuum.
regards
Mech
During a recent tune up I changed the PCV valve. Here is what I found; the original valve is on the top. No guts, no valve. The OEM Honda one is on the bottom and is shown as the correct part number for my VIN both online and at the dealership.
I bought the car with 224K miles on the odometer and as far as I know the PCV valve was original. I did put in a OEM Honda PCV valve, but I saved the "old" one just in case.
ZO.
Big Oil hates lean-burn.
Originally Posted by cowmeat View Post
If my hypermiling in the Insight cancels out the effects of just one gap toothed git-er-done in his big dumb F250 dually with his inbred kids and pitbull hanging off the side rails in the back, glaring at me as they roll coal around me . . . . . then maybe there will be some gas left when my grand kids start to drive.
