Old 05-11-2014, 11:53 PM   #15 (permalink)
user removed
You got it. I would just punch a hole near the check valve, then you could just cut an inch off an reconnect it if you wanted to remove the gauge. Get a piece of tubing or a tapered fitting and stick it in the hole (maybe with a little adhesive caulk), run the hose for the fitting to your gauge, use an existing access hole in the firewall (repeating myself).
regards
Mech
