Old 05-11-2014, 10:58 PM   #16 (permalink)
user removed
If the part you get does not look like the one you took off, then make sure you can reverse that part replacement. I prefer original equipment, unless the difference in cost is exorbitant. I did not like using my customers as guinea pigs to experiment with cheap parts, when I warrantied everything for a year and unlimited mileage. These days with chinese imports the quality issue is a magnitude worse than it was in 1999.
Picture below, just drill a small in the hose and stick one end in the hose (use some adhesive sealer if you want),
regards
Mech
