Old 05-11-2014, 11:07 PM   #17 (permalink)
DOFZO
DOFZO's Avatar
SLOMOTO - '92 Honda Civic VX
90 day: 56.49 mpg (US)
Originally Posted by Old Mechanic View Post
You got it. I would just punch a hole near the check valve, then you could just cut an inch off an reconnect it if you wanted to remove the gauge. Get a piece of tubing or a tapered fitting and stick it in the hole (maybe with a little adhesive caulk), run the hose for the fitting to your gauge, use an existing access hole in the firewall (repeating myself).
regards
Mech
Thanks again! I'll post pics up when I have it installed. Maybe someone can use this tread as well.
If the part you get does not look like the one you took off, then make sure you can reverse that part replacement. I prefer original equipment, unless the difference in cost is exorbitant. I did not like using my customers as guinea pigs to experiment with cheap parts, when I warrantied everything for a year and unlimited mileage. These days with chinese imports the quality issue is a magnitude worse than it was in 1999.
regards
Mech
If this is about the hose, there's a '94 Civic sitting in the junkyard that I'll source the hose from.
It it's about the PCV valve, the one I installed is OEM Honda, but you're not the first person I've heard say the VX didn't really have a PCV valve so I saved the original one just in case I notice a difference with respect to the engine/mpg/idling, etc. The OEM Honda (part #17130-PM6-003) does have a valve in it.
I appreciate all your help! I'm excited to get the gauge installed, to "see" the health of my engine and to improve my "pedal control"!
ZO.
Big Oil hates lean-burn.
Originally Posted by cowmeat View Post
If my hypermiling in the Insight cancels out the effects of just one gap toothed git-er-done in his big dumb F250 dually with his inbred kids and pitbull hanging off the side rails in the back, glaring at me as they roll coal around me . . . . . then maybe there will be some gas left when my grand kids start to drive.
