These angles are for two wheel vehicles with a fair amount of ground clearance. The flat bottom template is primarily on cars. That's the simple version as far as I can tell. Fred Hayes uses an Aerotech Bonneville style low tail, but the word from fellow riders is the higher tails are more stable. We have been looking to get low drag and stable handling which includes some down force on the front. The Vetter front is a proven, if expensive, piece. Try to make the whole package smooth and flush, start with the rear wheel since it will be more exposed.
