Old 05-13-2014, 11:41 AM   #24 (permalink)
cRiPpLe_rOoStEr
I had previous experiences with single-arm wiper in the Fiat Uno, and it didn't bother me at all.
Anyway, if you would consider to make some aeromods in the 106 I'd tell you to use some lighter materials to reduce the weight penalty in city traffic, since the energy spent to break the inertia and put the vehicle running is always higher than to keep it running at a constant speed. What about a Kammback extension? You could make it for cheap using Coroplast, and if you would consider to replace the entire hatchback with a custom piece already integrating the Kammback you could reinforce it in some spots using fiberglass (or eventually some old rags soaked in glue if you would rather wanna go the dirt cheap way).
