Old 05-13-2014, 06:13 PM   #18 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Old Mechanic View Post
If you still have the bent lower control arm and the front end was aligned with the bent lower control arm, then I would bet the tie roads are not the same length.
Rack must be centered AND tie rods must be the same length.
regards
Mech
When I take it in tomorrow to get the control arm replaced, and they do an alignment that will fix it right? Or should I say something to them about it?
