Old 05-14-2014, 07:12 AM   #10 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
I put an AutoZone alternator in my Accord and then an elk headbutted the car.
This is anecdotal evidence and requires ABA testing.
While a visual check is better than none it is best to use a volt meter. Just as easy to clean without checking and take very little time. I recommend you clean the ground using a small rotatory tool with with a brass brush, less likely to remove the coating protective coating from the connectors.
