Make sure the battery is good and fully charged. If the lights are still flickering with a good battery then I don't think the alternator will solve that problem. You can check the grounds with a volt meter but a visual inspection and no ground cleaning is a recipe for a later post "Well I replaced the alternator (or regulator) and it still has flickering lights".
Replacing only the regulator leaves you with an alternator that has seen many miles and is still a potential failure.
regards
Mech
