So just for a recap, this is what I have done so far to try and cure the problem.
Front end alignment + fix the left control arm ($195).
Balanced every tire and had the (worst) bent rims relocated to the rear.
Replaced one rim and had all 4 tires made sure they were balanced right ($55).
Replaced right control arm and replaced another bent rim + another alignment ($246).
Replaced the last bent rim and rechecked to make sure all rims are balanced ($55).
I have had my dad and 3 mechanic shops look at the car and nobody can find out what the problem is. I'm at a complete loss.
