Old 05-15-2014, 11:46 PM   #48 (permalink)
ecomodded
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Don't feel to much like you wasted money as the shimmy improved, that means the looseness was taken out of your front end , not the cause of the shimmy but the weakness showed up because of the vibration.
You bent rims showed you the loose front end.
Like mech mentioned, bad rubber , bruising caused by the rim impact , I think your problem is solved - replace the tires or wear them out like is.
I will suggest to replace the tires (at least keep your speed down for now) as they are more n likely damaged internally from the impacts , also the vibration will start to wear out the front end parts.
Save gas
