Originally Posted by Baltothewolf
the UG kept throwing temp warnings (UG was 167F and the limit is 145)
Was that the default setting? You set any limit that you want. I'm not sure what the limit would be in your car but maybe at least 185. I think in the 190's is fine for my civic so I set the limit for 204, unless you mean the inside the car temp. If that's the case, please disregard.
if I take it out of my car when I go inside, will I lose all the calibration I do on it?
No, the ultragauge keeps your settings.
