So aside from needing a ton of hours of sanding and repainting to make it all smooth, I've basically finished off the front grill blocks. Its all bondo and expanding foam. I decided to make it permanent after figuring out the "hole size" with duct tape. Coolant temps never go above 206, and usually stay around 198-202 range.
All-in-all, I'd call it a success!
