Originally Posted by johnlvs2run
Thanks for those details. The 12"x25' was aluminum, quite light compared to the steel, that I could hardly pick up.  I'm going to try a plastic nose, and will keep the flashing in mind for next time.
Cool! Glad I could help. Aluminum would definitely have some added corrosion protection. If you use plastic you might think about getting a heat gun, to aid bending into shape. (one of the reasons I use metal)
