Old 05-16-2014, 12:20 PM   #3 (permalink)
colinr
Originally Posted by mikeyjd View Post
Max sidewall psi in the tires + a grill block should get you a couple more mpg.
I'll check out the tires, good thought thanks for that one. I know what I'm doing tonight
I've read about the grill block and it seem a little counter intuitive to proper cooling of the radiator and fluid, the airflow is there for a reason for the most part in my opinion.
I live an a wildly swinging climate, -20 in the winter, +40 in the summer with 70-80% humidity, a grill block in the summer would probably cook my engine pretty quick, but would probably be worth it in the winter.
Anyone have experience with a blocker in these climates?
Southern Ontario, Northern NY(Buffallo-ish) area?
