Old 05-17-2014, 10:26 AM   #23 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Its best to activate the surface before sticking on tarp tape...I use a propane torch.
In order to glue one piece of Coro to another, CA glue may be used. Unfortunately, it is not enough just to apply some glue to the parts to be bonded. By nature, the plastic used for making Coro does not bond well unless its surface is first "activated". A common technique for achieving this is called 'flashing'. This involves passing a flame over the surface for just a moment, being careful not to melt the surface. A hand-held torch seems to work well for this task and can be purchased for under $15 from your local hardware store. Test your technique on a scrap piece first. Water should not form droplets, but a thin film on properly activated Coro.
- Tony
The Following 2 Users Say Thank You to arcosine For This Useful Post:
aerohead (05-17-2014), Xist (05-17-2014)
