Old 05-17-2014, 02:53 PM   #366 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by stewie View Post
Thanks T vago. Can i take you up on the offer and send you the chip to reprogrammed it? I think you said it's $5 ? I can paypal your account.
I was considering charging $5, but I did a more detailed analysis of what it would cost to purchase the raw chips, program them, then send them off. I've decided that I can ship off pre-programmed chips for $10.
If you're not interested. Can i buy this dev board and put in 328 chip launch andruiono IDE copy and past code into sketch and upload using this board.
Is there any extra code that is in the 328 chip as i noticed chip code in in hex and there is some memory flashing going on. Is Androina IDE addressing all 32k of memory space to address bootloader and other stuff too when compiling?
Certainly, you can use the Arduino Uno, like what you found at NewEgg. You might even find an Arduino Uno at your local Radio Shack. The IDE does address all 32k of the AtMega 328 through the Arduino Uno. I do remember that one of the changes to the IDE I made to support the JBD board was to replicate the Arduino Uno settings to make a new "JBD Board" entry under Board | Tools, and change the clock speed from 16 MHz to 20 MHz. That was actually pretty simple to do.
