The idea of using a resistor on Acura/Honda engines to trick the ecu into thinking the intake air temp is "normal", when using a WAI, would probably work. I'm pretty sure Acura/Honda ecu's retard timing automatically when the IAT is high...beyond the point that would be needed to avoid knock. I have no way of measuring my ignition timing while driving as my car is pre-OBD-II, however I plan on running my WAI for a few tanks, then will add a resistor to reduce "measured" IAT by 80-100 degrees. Then run a few more tanks and see if there is a difference. The bonus with my set up is that I'm running E85 which is 105 octane, so knock is not really a concern.
Question: For the same given power output of an engine, would the vacuum be higher or lower when the intake air temp is significantly higher?
E85 ~$3.17/gal.
