Old 05-18-2014, 09:57 PM   #375 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Hm... Starting at or about at line 225 of the code, what do all of your "#define" statements look like? They should look something like below:
(also - with the Uno, make sure you're just using File | Upload, not File | Upload using Programmer )
Code:
// if the below "#define"s are commented out, code will compile for an AtMega328-series processor
//#define ArduinoMega2560 true
//#define TinkerkitLCDmodule true
// if the below #define is commented out, 16 MHz system clock will be assumed
#define use20MHz true // force 20 MHz system clock values
// only one of the below LCD options may be chosen - choosing more than one will cause a compilation error to occur
// if TinkerkitLCDmodule is used, useLegacyLCD will automatically be used, and the below options will be ignored
#define useLegacyLCD true
//#define useParallaxLCD true
// only one of the below button options may be chosen - choosing more than one will cause a compilation error to occur
#define useLegacyButtons true
//#define useAnalogMuxButtons true
//#define useParallax5PositionSwitch true
// the below options only work if useLegacyLCD is selected. If useLegacyLCD is not selected, the below options will not be inserted at all
//#define useLegacyLCDinvertedBrightness true	// For alternate LCD backlight connections
#define useLegacyLCDbuffered true				// Speed up LCD output
// selectable options - all may be chosen independently of one another, save for serial data logging.
// the serial data logging option will conflict with the Parallax LCD output option, if both are selected at the same time
//#define blankScreenOnMessage true		// Completely blank display screen upon display of message
#define trackIdleEOCdata true			// Ability to track engine idling and EOC modes
#define useSerialPortDataLogging true		// Ability to output 5 basic parameters to a data logger or SD card
#define useBufferedSerialPort true		// Speed up serial output
#define useCalculatedFuelFactor true		// Ability to calculate that pesky us/gal (or L) factor from easily available published fuel injector data
#define useWindowFilter true			// Smooths out "jumpy" instant FE figures that are caused by modern OBDII engine computers
#define useBigFE true				// Show big fuel economy displays
#define useBigDTE true				// Show big distance-to-empty displays
#define useBigTTE true				// Show big time-to-empty displays
#define useClock true				// Show system clock, and provide means to set it
#define useSavedTrips true			// Ability to save current or tank trips to any one of 10 different trip slots in EEPROM
#define useScreenEditor true			// Ability to change any of 8 existing trip data screens, with 4 configurable figures on each screen
#define useBarFuelEconVsTime true		// Show Fuel Economy over Time bar graph
#define useBarFuelEconVsSpeed true		// Show Fuel Economy vs Speed, Fuel Used vs Speed bar graphs
#define useSpiffyBigChars true
#define useFuelCost true			// Show fuel cost
#define useChryslerMAPCorrection true		// Ability to perform on-the-fly fuel injector data correction for late-model Chrysler vehicles
//#define useABresultViewer true			// Ability to graphically show current (B) versus stored (A) fuel consumption rates
//#define useCoastDownCalculator true		// Ability to calculate C(rr) and C(d) from coastdown
// program measurement and debugging tools
//#define useCPUreading true			// Show CPU loading and available RAM usage
//#define useDebugReadings true
//#define forceEEPROMsettingsInit true
//#define useEEPROMviewer true			// Ability to directly examine EEPROM
//#define useBenchMark true				// this is probably broken - last time I used it was in August 2013
//#define useSerialDebugOutput true
// SWEET64 configuration/debugging
//#define useSWEET64trace true			// Ability to view real-time 64-bit calculations from SWEET64 kernel
//#define useSWEET64multDiv true			// shift mul64 and div64 from native C++ to SWEET64 bytecode
The Following User Says Thank You to t vago For This Useful Post:
stewie (05-19-2014)
