Old 05-19-2014, 03:46 PM   #16 (permalink)
aerohead
cooling system drag
Originally Posted by OKXXFE View Post
So according to some info I found 'round here that I think may have originally been posted by Aerohead (?), the cooling system or just the engine bay in general is responsible for about 30% total aero. drag. By blocking off just my upper grill I achieved (conservative first estimate) 10-15% increase in FE. It will be interesting to see if fully isolating the airflow from around the engine will actually increase my overall FE to anywhere near the theoretical 30%. I know I have a whole lotta work to do in fabricating what I want and also the testing testing testing.
Does anyone know if the SGII or UG can compile select data for a spreadsheet? The easiest way I know to determine if variables are effective is to show it on a graph and plotting by hand is super tedious.
As it's Sunday, I think today is a good day for cardboard mockups and a trip to the hardware store! don't tell my wife...
The experts would tell us to treat each vehicle on a case-specific basis as far as numbers go.
In the past,messengers suggested that a production cooling system would be responsible for about 12% of the overall aerodynamic drag.Hucho,in the mid-1980s suggested that the drag of a carefully designed cooling system drag could be reduced to 2% of the overall drag.
Fiat published an SAE paper in the 1980s,based on wind tunnel studies of a 1/2-scale model with very detailed underbody.
Their tests showed that completely blocking off the cooling system didn't necessarily eliminate the cooling system drag.It might reduce under-body drag,while increasing upper-body drag.They did mention that this phenomena warranted further study.So this is the exception to the rule.************
We do know that positive thrust was achieved in the North American P-51 Mustang cooling system do to heat flux air expansion.
Walter Korff,aerodynamicist for Lockheed, tested the system diagrammed ,and demonstrated low drag.(so something as close to it should pay dividends).All NASCAR race cars use Korff's inlet geometry and airtight ducting.
A look at the 1978 Pininfarina CNR 'banana' car illustrates the pains Dr. Alberto Morelli went to to design a low drag cooling system.(he could easily have spent a $100,000 in wind tunnel time just to develop the extractor vents,which blend the cooling system air at matched-velocity to the surrounding flow as it emerges).
The 1987 Oldsmobile AEROTECH,closed-course LSR racer demonstrates careful attention to heat-exchanger airflow.
We might want to think of mpg increases on the order of 6% for a perfect system.
